Yes - you could even run two additional PTO’s with a SM465.Can you run the PTO with a manual transmission? If that th400 blows up I would put a manual back in![]()
Hmmm, the existing Warn 10K is non-functional, maybe I need to research PTO winches.Yes - you could even run two additional PTO’s with a SM465.
Kilmat from Amazon is a good price and one box covers alot.I ordered vinyl floor cover from http://www.73-87chevytrucks.com/
It comes with the padding/insulation which I need as I would like some temperature and noise control.
I am not sure I want the expense of dynamat - is there a decent spray on product I can use under the padding? I am thinking of the thick black stuff you put on fender wells and frames, the name escapes my very tired (weak at best) pea-brain.
YepSince the truck has load winches I am researching straps and the tying of them. I came across this video and I learned a lot! Did you all know this already?
20+ years ago i had the same problem with a ACC mat kit . Looks like they still have not got the bugs worked out yet .I think some of the wrinkles will smooth out after some time and hot days.
View attachment 528287View attachment 528288View attachment 528289
Looks like my floor mat lolI think some of the wrinkles will smooth out after some time and hot days.
Not an easy job now with the vinyl flooring, fok.I put the tunnel back on before I thought about taking pics of the th400 for identification purposes…Not an easy job now with the vinyl flooring, fok.
Not trying to spoil your efforts at all but that picture is of a 2WD cover that offers no structural integrity and won’t allow for use of the two strut rods ( unless they were deleted when the conversion happened ).OK. I just put a new converter cover on it as it was missing. This fit perfect, don't know if that helps.View attachment 528526
