Chevy NP205 from a turbo 400
HelpMyZ
Quantico Virginia
just like it says, I need a 32 spline 205 for my turbo 400 (Originally had a 203 there) would also possibly be interested in a tranny and t-case combo if the price is right, from flexplate to output shaft.. anyone have anything?
What kind are you looking for?? I have both style inputs, one case/adaptor. If you have a round pattern 205, I have the input. The other one is the case, but at the moment no input, it's in the Ford 205 in my truck. That one has the adaptor....
heres what I've got, looks like it's the round style with a short output, so I think that I need a whole new tranny and t-case or??
is there such a thing as a long output and a short output cuz what I've got doesn't look like it would be long enough to make it through one of those np205 adapters
info for ya.
th350 has 1 tail shaft for 203 and 205. same length.
th400 has a few diffrent. 203 has your stubby one. then 205 has i think 2 diffrent ones as to the vintage of the 205 32 spline input length.
i have a complete minus shifter 32 spline 205 with fig 8 style adaptor for sale. plus shipping and thay are heavy items. flat flange frt and fixed rear from a 1ton truck.
i have the frame braces also or a brace rod to bellhousing also.
and a few hd ears for 1/2 and 3/4 ton crossmembers only as 1 ton is diffrent.
pm me if you want to work out a deal.
sweetk30 said:
info for ya.
hi jack will a 205 for a 400 bolt up in place of a 208 if you change the adapter and all???
ummm.. so the 205 I have is from an 1987 one ton with an sm465.. I THINK that means it's a 32 spline?? does that mean that all I'd need is the 400/205 adapter and a new output shaft for my 400??
That 205 is the same as the 400 version of the same year. Not sure about the output on the 400 though.
