ScottyREwing
Registered Member
- Joined
- Apr 14, 2013
- Posts
- 7
- Reaction score
- 0
Hi folks... could use some brainstorming from you smart types
Monday my 74 GMC K1500 4x4, Automatic transmission, 350 chev, decided to overheat. It's been running pretty hot for ages and it's definitely not due to fluids as they are fine. I'm thinking the source is the thermostat in the main rad hose at the engine connection. Ran into that before. Will get that done soon. This however isn't my problem... only when my true problem began.
After I let the truck cool down, I hopped the curb and went the other direction out of traffic and got the air blowing through the rad and brought the temp down. I was about 20 minutes down the road in top gear running about 50mph when it started sputtering and coughing and bogging down to the point that I could only drive under gentle fuel peddle application and under 40mph. It continually got worse to the point where it now does this the moment I am under load and the truck shifts into 2nd gear and above. It will remain even when I slow down and drop to first gear but it corrects itself if I take the load off the engine for a moment or two. In Park, neutral it rev's just fine... no stuttering and choking itself out. I can even blast around in first gear all over a parking lot like a hooligan and no problems. Only once the shift takes place does the problem happen again.
I checked all levels on Monday and the tranny was dangerously low so my gut tells me its the torque converter (?) that controls the shifting inside the transmission. I have topped up the tranny since this realization. I have also read recently that it could be the EGR valve?
I'm looking for all kinds of thoughts from you guys to assist in my diagnosis so lay it on me.
Thanks in advance
Thanks in advance
