Cleaning IAC
Hossbaby50
3/4 ton status
Peoria, AZ
What is the procedure for cleaning the IAC? What do you use to clean it? I am trying to track down the rough idle in my TPI setup and want to clean the IAC and see if that helps at all.
Harley
Just carefully wipe any carbon off the pintle seat and do the same inside the throttle body seat. Be carefull not to push/pull/twist on the pintle though or you'll ruin the IAC motor.
I'm not sure if there is a tech article on thirdgen about this, or just a VERY detailed post.
It's in depth, that's for sure.
