cleaning?
85posjimmy
Cedar City UT
i am getting my manual and 205 transfer case ready to install, but my trasfer case is really dirty and grimey. what would be a good way to clean it off. i want it all clean when i install it so its nice and clean. thanks Marcus /forums/images/graemlins/thumb.gif
hey thanks for the tip. portland OR huh wow i grew up in vancouver WA pretty neat. thanks marcus /forums/images/graemlins/thumb.gif
go to costco or shucks and buy oil eater spray on pressure wash off..
The best stuff I have found to remove grease and gunk, is Castrol Super Clean. You can usually find it at the auto parts stores or Wal-Mart for around 4-7 bucks a gallon and it comes in a purple jug like antifreeze. This stuff works wonders, and it is biodegradable and water soluble. I will usually take a tub a little bigger than my part, and fill up about an inch of cleaner and using a brush and scraper, clean everything and then rise off with the hose. great results. Caution though...this stuff is caustic and WILL remove the first few layers of skin if you use it without gloves. It will also remove paint if you leave pieces in it to soak. A few shops that I know have now replaced thier solvent with this stuff since it is cheaper and works just as well without being flamable.
Brake clean works good, and even gasoline. I worked at a transmission shop, and we used brake clean all the time for just about everything. Just spray some on, scrub a little, and rinse
the super clean works great so doed the old reliable brake cleaner and wire brush. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
Super clean is the sh!t!!! My wife even uses it for everything around the house but windows!! /forums/images/graemlins/waytogo.gif
