click, click, click goes the suburban...
Discussion in 'The Garage' started by muddysub, Aug 19, 2002.
  1. muddysub
    muddysub 1 ton status Staff Member Moderator GMOTM Winner
    Jun 23, 2001
    10,911
    1,668
    my garage, Henderson, NV
    Build(s):
    hey, as some of you know i ACCIDENTALLY /forums/images/icons/crazy.gif jumped the suburban about a month ago. now there is something clicking under the front end of the truck. /forums/images/icons/frown.gif every bump i hit, even on paved roads, it clicks. what could this sound be coming from? i'm gonna remove my sway bar in a week i'll see if that helps, but if it doesn't i don't know what the sound is. help me out here please. /forums/images/icons/frown.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like when you made the jump somthing brooke /forums/images/icons/shocked.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Hey scott, I found the rattle/clicking sound my sub was making that I told ya about...my battery tray broke...something to look at anyways...good luck.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    check those things that wraparound the springpacks. it rattles on mine.
    nathan
  5. muddysub
    Jun 23, 2001
    10,911
    1,668
    Build(s):
    cool i'll check those things any other suggestiuons.
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    It could be as simple as busting a few bolts out of something like an inner fender and now it rattling arround. You never know.
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Can you get it to make the noise by jumping on the front bumper?
  8. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Yeah, battery tray is very common. Just welded mine back up a couple weeks ago in the Suburban.
    Ken H.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,900
    1,133
    Grand Rapids area
    Build(s):
    I jumped a sub once and broke a leaf. It would go clang, clang a little on bumps. Got worse with time, too, as it starting walking out of the pack. It was the one with the clamp attached to it.
  10. muddysub
    Jun 23, 2001
    10,911
    1,668
    Build(s):
    thanks guys, i'll check it out. /forums/images/icons/smile.gif
  11. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    you might have broke something in your hub /forums/images/icons/frown.gif , mine was doing that, and thats what it was.
  12. Clay's 72K5
    Clay's 72K5 Guest
    The suggestion of standing on the front bumper is a good one. Jump on it a bit to see if you can get it to click. If so you have a decent chance of hearing it well enough since the engine is off to be able to pin point where it's coming from or at least narrow down the area a bit.
  13. muddysub
    Jun 23, 2001
    10,911
    1,668
    Build(s):
    the hubs are fine, the bearings are new and i've been wheelin since then and i was 4 wheel drive.
  14. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Maybe you got a visit from the "Locker Fairy" /forums/images/icons/laugh.gif Maybe you've got a bent flexplate and there's a bolt tapping your inspection cover.
  15. muddysub
    Jun 23, 2001
    10,911
    1,668
    Build(s):
    i don't have a locker and i know exactly what's wrong with my flexplate. it's gettin replaced this year.
  16. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Check your front pads if thay rattle between the calipers and the roters or just get a lauder stereo.
    89 sub, 350 tbi, 465, 31s for now
  17. muddysub
    Jun 23, 2001
    10,911
    1,668
    Build(s):
    the louder stereo is in the mail right now. /forums/images/icons/wink.gif /forums/images/icons/grin.gif
