fordtruggy
Registered Member
DougK20 said:Tom Woods $950
Yikes!! My PTO cost me about 150.00 and is just as strong but has 3 times the slip yoke.
stallion85 said:Doug K20 is that a factory tranny crossmember?
Yeah, for my 350/400/208 combo. I found it satisfactory for my needs. Other than bolting on a skidplate, it was never altered. Too bad the exhaust is so uglystallion85 said:Doug K20 is that a factory tranny crossmember?
Its pretty bad. I wish I had the coin for a better then stock CV. I did grind the stops down a bit since Im supposed to be going out this weekend. Going to lengthen my spare so that incase I do blow it I will still have a usable spare. Anyone know of any good junkyard CVs to look for?85mudblazin said:What does your front DS angle look like?? Can you put a angle meter on the ds for me??
jays68yak said:Its pretty bad. I wish I had the coin for a better then stock CV. I did grind the stops down a bit since Im supposed to be going out this weekend. Going to lengthen my spare so that incase I do blow it I will still have a usable spare. Anyone know of any good junkyard CVs to look for?
If I did not grind it down it was binding just sitting there. Not too bad, but it was enough to make me grind away.
