Okay I know I need a new clutch but the only time it seems to slip is in 4th gear, have done the whole shift down thing to see if the clutch is bad and that test makes it seem fine.
I just want to be prepared when I do it, I am guessing the rear main is leaking so I will get a gasket kit and regasket the motor while it is out(yah I will just pull the motor to change the clutch)
So any other ideas of what it could be?
The truck is a 73 2wd dually 454 motor
