Code 42 and slow to move once in drive
hambone933
NC
Evening gents, it has been a while since the last post. After what seemed like an eternity, the brakes on the Blazer are finally working. Story for another post if anyone cares. So, I have installed new window regulators in the truck. The driver side is great. The passenger side makes a growling noise at a certain point then goes away. Almost sounds like the gears are grinding. This has caused the service engine light ro come on and throw code 42. Now the truck doesn’t want start or run. Almost sounds like it is out of timing. Is it possible this regulator could cause this issue? Also, now that I have brakes I have been able to move the truck under its own power. But the transmission seems slow to move in drive. Any suggestions. Oh by the way, the cure for my brake issue was found right here. Thanks again guys for the knowledge.
Code 42 is an igntion timing code.
The
window motor doesn't have anything to do with the engine not starting. Always a outside chane of a wiring snafu.
As for the no start we'll need more info.
3 things necessary to run spark compression and timing to run
You are missing 1 of these
It is weird how as soon as the problem with the regulator started, the check engine light came on. I will check for any wiring issues.
