sanddragon2004
so i have this 90 burb just picked up.
has tbi 350.
surges at idle. and is running lean.
i pulled the codes and get
error code 44.
so far ive replaced the tps coolant temp sensor, fuel filter,
and throttle body gasket.
still does it.
new plugs new cap rotor. under the rotor looks rusty but not munged up.
hard to start and then surges when it runs. IM wondering if the 02 sensor might be bad.
when i rev it up it boggs and acts like its starving for fuel or maybe timing.
trying to figure out all the cheap stuff first before i start pulling fuel pumps an what not
anybody got any ideas?
has tbi 350.
error code 44.
still does it.
Not enough fuel from the injectors will cause a lean exhaust.
