Yep, certainly sounds like either a bad neutral safety switch or it isn't adjusted correctly. You will have to either bypass the switch by joining the wires together or replace the switch if it's bad.
thanks so much. can someone describe to me what this switch looks like? i haven't seen any switches that i'm not familiar with in this particular process... sort of.
u jinxed my problems!colbystephens said:well, thanks to all of you and particularly Ron (POWERMAD) and Matt (1976blazer...??) it's all running and good to go!!
Ron came over today and we cut out the park/neutral safety switch and wired those wires together, as well as found a few bad grounds, installed a headlight relay kit, the starter and a handful of other discoveries. Got the truck up and running real nice. fixed my GP solenoid too!! truck fires up like a champ - less than 1sec crank time.
doing a bit of wheeling next monday/tuesday, so expect updates from that!!![]()
my truck is havin electrical problems now!
seriously, glad to hear u guys got it sorted out!
not to hijack, heres the link for the 80 gmc problems now. http://coloradok5.com/forums/showthread.php?t=215490colbystephens said:what's up w/ your rig?
how do i fix it? it's dark, so i can't see what's up at this point. easy fix?
jekquistk5 said:replace your wheel cylinders. shouldn't be hard at all
