I would pick up a used factory CAI at a pick n' pull and try that first... I used to be into 3rd gen camaros, and many of the guys over on thirdgen.org have proven that until you get into a heavily modified motor, that the factory cold air setup will flow more than enough cfm's to feed your motor cooler air than an open element. Now many of them pull the thermac device out of the snorkel and a few other simple mods, if you do a search for tbi mods or ultimate tbi mods you should come up with a lot of info about the factory setup that could be applied to a carb as well. I wouldn't use any aftermarket kit that doesn't drawnoutside cold air, they've been proven to be no better than an open element filter...
