for what its worth if you have a decent flowing stock system its better to throw a k&n drop in filter in than a full cold air. i've put a drop in filter in 2 of my cars both saw 1-2 mpg increase but nothing noticable in performance. i got a deal on a full cold air intake system and installed it. no change in mpg if anything i saw a bit less than the drop in, it did change the tone of the engine to be a bit louder. the other lesson i learned was when in cars always spring for a bypass valve as they will not hesitate to suck up water and flood your engine.
the only way i could see the cold air making a big difference is if you opened the exhaust up or had a restrictive intake in the first place. for the rest of my cars i'm sticking with the drop in k&n and similar as the cold airs arent worth the trouble.
