cabledawg
Secret Squirrel
Its an 88 Chevy Burb with a TBI350. About a month ago when we had constant sub-zero temps, it started to get hard to start. Cranking longer before firing, then needing ether when the engine was cold, to needing ether all the time even if I just shut the truck off. Seems to run fine once it starts and a little squirt of ether is all it takes to fire up. With the temps coming back up I though the issue would go away, but it hasnt.
I've changed out the temp sensor and I ran some Lucas Oil injector cleaner through it. I dont think the fuel system is bad so I'm looking at the ignition system. But before I do anything else, anyone have any suggestions as to what happened? I dont like goose chases and I'm stumped on this problem.
