Coming soon to TSC - Federal spec Military camo colors for Al's Liner!
Blaze
Raleigh, NC
Available EXCLUSIVELY at Triangle Specialty Coatings!
We are testing out the samples this weekend. So far we've got the mix worked out for 383 OD and 686 Desert Tan, and hopefully we'll have 383 Brown worked out by Friday. Other military colors will follow as demand arises.
Test panels will be sprayed this weekend. I'm hoping I can keep the cost down to either equal to, or only slightly more than a standard Al's kit.
Flat additive can also be purchased through us for an extra $10/gallon.
We will be the only place where you can get a flat camo color for your rig in a spray-on bed liner material that is made specifically from Federal specs!
I will keep you all informed on when they will be available and post up pics as soon as I have them.
Initial results are positive. Don't mind the texture, I didn't want to have to bother cleaning the gun for such a small amount, so I used a roller.
The top is 383 Olive Drab
Bottom is 686 Desert Tan
Friday I'll have some 383 Brown
Here's the 383 brown. Don't mind the mess, I ran out of rollers, so I smeared it on. :haha:
I tried rolling it on, but I was very unhappy with the results. I'd recommend spraying it. When you roll it on, it is way to thin. You can get a much better thickness when you spray it due to the viscosity of the Al's material.
