Common light issues?
blazinzuk
Buzzbox voodoo
Rexburg Idaho
I know I got to have a bad ground somewhere.
But just wanted to share.
In the last 3 days I no longer have brake lights ( switch is good). I no longer have tail lights. But I have turn signals, unless the lights are on bright, then I only have right turn signal. Lost the dash lights and the headlight has decided to blink with the blinker and I no longer have hazards.
But my domelight started working again
Ugh
Hacked or corroded trailer wiring often causes these kinds of issues--poor grounds too..dash lights should be on a separate fuse,so grounds would be my guess..
I don't think it's been mentioned yet, but for what it's worth, you might want to check those grounds!
Lets bring this topic back up from out of the ground.
You best be groundkeeping by the instrument cluster and behind both tail lights.
All I know is I'm looking for grounds. If those are up or down I don't know.
I think if they are sideways I might have issues
Just remember to keep your head and stay grounded. These things can drive you crazy.
