Well let's put this thing in the ground.
As in 3 broken grounds. 2 kind of obvious, 1 broken back in the loom.
I took out the 3 different attempts at trailer wiring as much as possible. Repaired every different wire at some point in the rear harness. Some wires were repaired at least 4 times.
I need to pull the rear stuff and replace everything eventually.
But all lights function fully
