1985 K10 Warhawk
Registered Member
Hello,
So, I chewed up the gears in my stock 1/2 ton rear diff of my 85 burban (4inch lift / 33s), doing a bit of rock crawling. Decided it's time to upgrade. (She makes a terrible clunking noise when ever I turn @ any speed.. so spider gear?)
I've been researching and reading the pirate4x4 14bolt bible (http://www.pirate4x4.com/tech/billavista/14b_bible/) and am unsure of if I need to be worried about the end width of the axles? If some one could direct me to other resources, I'd put the research in too!
These are located on:
If I plan to buy all new gears / lockers.. do I need to worry if the vehicles I may get them from have like 200k+ miles on them? Should I avoid any specific one?
I have a friend flying out in 3 weeks to help, so I want to ascertain an axle from CL/junk yard and build it before he arrives. I have access to a work shop with a welder (Although neither of us have done it before, learning experience opportunity)
Help!
- 73-96 C20, C2573-00 C30, C3573-00 G30, G3573-00 K20, K2573-00 K30, K3584-88 CUCV
- 88-91.5 V30
Help!
