Continuing 72 Blazer build
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by IRIECHEFDEEZY, Jul 8, 2013.
  1. IRIECHEFDEEZY
    IRIECHEFDEEZY Registered Member Premium Member
    May 28, 2012
    91
    11
    Atlanta
    Took a break from all the bodywork this weekend since the floors are more or less done. Installed new poly bushings and a 1" body lift from ORD. Install was pretty smooth. The only hiccup is now it's too tall to exit the garage. We need some low profile tires for the rollers, or we'll be airing down the tires when we want to work outside.
    ashman likes this.
  2. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    Put the front clip back on the truck today. Checked the front grille fit. 71chevy4x4 wanted some pics of grille fitment. The grille will have to be trimmed to almost the eggcrate portion to clear the abomb.
    Also checked the fit on our Griffin radiator while we had time.
    All this was done to prep for cage work which should start in the next month or so. It was nice to see her looking like a truck again.
    bmxbryant9, max 02 and ashman like this.
  3. 71chevy4x4
    71chevy4x4 1/2 ton status Premium Member
    May 30, 2006
    136
    5
    Portland, OR
    Thanks for posting pics! I'm not willing to cut a large enough hole in my grille to use the abomb with my 8274
  4. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    Maybe a Sunday drive to the ice team parlor or Saturday car show. That's about all.
  5. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    No problem at all! Yep an 8274 would definitely wreck your grille.
  6. CK5
    May 19, 1999
    22,031
    1,154
    CO
    Build(s):
    What are your cage plans?
  7. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    We don't really want to invest in a bender setup, so we're looking at some prefab cages. Probably an 8 point with a similar layout to the crappy one we removed.
    We're going to tie the gage into some rock sliders and frame points underneath to give us some extra rigidity as we're not going to be putting the rocker boxes back in. It will be interesting to see it all come together.
  8. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    We ordered a cage from Summit Racing yesterday. We were looking at Bronco Bobs' cage and a few others, but didn't want to pay for freight. So we ended up getting the competition Rhode Racing 10 point cage with tube specs of 1-5/8"X.134" cage and we will go to Summit Racing in McDonough, Ga. to pick it up. The Summit Racing part number is RHC-13-0344,
    any of y'all use this cage and have any tips on installation? We may change up some of the setup and customize the cage for a tire carrier in the back.
  9. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    while we are waiting on the cage to be built and delivered, I want to start looking into the mechanical upgrades. what is everyone doing to upgrade the braking system? what years are best for the 454 blocks? what recommendations do y'all have for drive shafts? Any help i appreciated. Thanks
  10. Lieferson
    Lieferson 12oz Curl Specialist Premium Member
    May 13, 2014
    123
    96
    Graham, Washington
    Easiest brake upgrade would probably be a 1 ton booster/ master cylinder
  11. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    What year 1 ton 3500 trucks should I look for? Are there any differences throughout the model changes that would make some year boosters better than other years?
  12. ekajkrats
    ekajkrats 1/2 ton status Premium Member
    Mar 6, 2012
    1,007
    348
    North SF Bay Area, CA
  13. IRIECHEFDEEZY
    May 28, 2012
    91
    11
    Atlanta
    Thanks for the replays, gentlemen. I'll look into those parts and that link. Start stocking up on parts while we wait for a cage.
