A while back I posted that I bought a mess of contura switches and a ton of stuff...
well I have been looking for a ac vented gauge cluster cover. I found one in the junkyard for $5 but it is all tacky.... it had a camo cover on it and when I pulled it off I cant get this glue out.....
anyway I got one that someone is going to give me for free when I go get it...
so it felt good to work on the truck.. havent really touched it since February as issues arouse all over the place...
I fixed my rear brake line leak then worked on my power steering leak...
then I got my contura switches in and my msd timing control mounted... got to get my msd sent out to be fixed then I will have a convenient timing control from in the cab!!!!!
anyway a few pics....
I could have mounted these to the gauge cover and still may as there is a gap that you can see....
so these swithes are....
accessory
windshield washers
front bumper lights (this one is going to go as you will see below)
also in the upper right where the ac vent is ... you unbolt it and these fit in there PERFECTLY!!!!!
these are going to be...
accessory
accessory
offroad lights (toggle up for bumper lights and toggle down for bumper and rollbar lights)
winch front (dont own the winch yet but hydraulic eventually up front)
winch back
winch switches are momentary on, off, on and the rollbar switch is on, off, on
someone brought up a good point that I should throw a safety switch in for the winches.. dont want to accidentally hit them and have them winch in or out... so should throw a power switch in which is what one of the accessory switches will be....
accessory
windshield washers
accessory
accessory
winch back
