Convert from 4wd to 2wd
any 72 to 87 crossmember will fit. theres no need for any camaro swap as anything you need is available for the truck. tubular a arms, 1-2-3" springs 2-2.5 or 3" drop spindles.. even 13" brake kits.
I would. it should all fit in nicely an with the after market companies today you can set that front suspension up to handle as nice as if you stock a camaro or nova front under, acctually probly better. What motor you gona run in it?
I am thinking about just doing a mild build to the stock tbi 350. It's not going to be a drag truck so I am going more for looks and being drivable.
