y5mgisi
1 ton status
Normally really dont like these tires but i was cruisin around on Pirate4x4 and seen this set of cut ones. I like em!
Looks like a bunch o penis's on his tire.
my t birds worked great in the sand,
maybe you had the special softwall edition
Well I started my reply by saying you got the wrong type, it's a bogger..., then I went back and looked at the pattern, it's a thornbird alright but cutting involved more than just cutting a grove in the lugs, he actually removed entire lugs down to zero to create a bigger void ratio, which made them almost like a bogger.
I liked the idea of the thornbird because it was a smaooth rider on road and could have a good bite once it sank, this definitely wouldn't have a smooth ride, I don't see why you would do that to a thronbird when you get the bogger like that from the factory, I mean it definitely wasn't easy removing these big lugs entirely.![]()
Might as well just by tractor tires.
