Coolant leak around intake manifold after frigid temps
muddybuddy
1 ton status
Northern, VA
So I’ve got a 350TBI, with between 5-10k miles on it. I fired it up and brought it to operating temp 2 weeks ago, with 35-40* outside temps, no leaks, ran great. Last week it was single digits for handful of days. Truck sat, never started during those days. I started the truck up New Years day, temps were back in 50’s and within a couple minutes of starting I noticed coolant all around the intake manifold valley on both sides (could have started immediately, i walked away right after starting so not sure when leak started). Hard to pinpoint where its coming from (the area around upper hose was dry, so thats not a culprit), seems all around the intake. The coolant was a 50/50 mix, or at least very close to that. Tried to get a couple pictures, didnt come out very well, but hopefully helps.
Could the exposure to the single digit temps expand (freeze) the coolant and stretch the intake manifold bolts and create a leak even if the truck wasnt run, assuming a reasonable coolant mix? Scratching my head on this.
What do you think? How severe could this be? Surely it couldnt have done something like cracked the block…could it?
Motor was in the truck when I bought last spring. Never had any coolant leaks until after the abnormally cold last week. No issues last year when it was in high teens/low 20’s.
Havent checked for coolant in oil, but thats on my list to check this weekend. Was short on time (truck is parked 30min away until spring), will try to determine if rtv or sealant for water jacket holes
My guess is it’s coming from the bolts
The low temperatures can expose a less than perfect seal. Cold leaks are a pain.
Hopefully it sealed up when closer to operating temperature.
Keep an eye on the oil condition, maybe see of you can find a test kit to check for coolant in the oil.
