Trying to understand the programming. How much does the coolant temp sensor signal in the ecm? It started great untill it warmed up last night.
Usually the other way around when a CTS goes bad. When they fail it tells ECM it's -40C outside and adds a ton of fuel for choke.Trying to understand the programming. How much does the coolant temp sensor signal in the ecm? It started great untill it warmed up last night.
Your right! It's a cheap sensor, but an OHM meter will test it in the truck and on our trucks it's to easy to get to. But it is third thing that wears in these systems.The coolant sensor fixed it. 10 bucks doesnt justify testing to me when the sensor is old anyways. Change the sensor for ****s and grins. No more CEL and it runs right.
Thanks for the help and info. The scanner I have now is from Eqquis but doesn't do live obd1 data. I'll look into the tunerpro
Like $50-$60 for a MAP sensor, $5. at JY! And I have never seen one go bad, ever! But I just read here I think that a guy had one fail...
