supersize75k5
OrganDonorRacing.com
The temp gauge on the buggy has been out for a while, I decided to throw one on so I can actually see where it is at,
its a mild big block, Ron Davis aluminum rad, I believe 195 t-stat and a electric fan, unsure on cfm but it came with the radiator and is built in.
according to the gauge it warmed up to around 220, then t-stat opened and it went down to 200 and stayed there, 107 degree day and all idle with some throttle input to try to see if it would raise it much.
?? water wetter time, or leave it?
I am running the correct 50/50 mix, to hot?
