Getting ready to install an electric cooling fan. Have a couple options on where to locate the switch. This is a single wire grounding switch sourced from an 87 Camaro V8.
First option would be the port on top of the water pump. My thought on this is that the fan would cycle on/off too quickly. Cooling the fluid and hitting the switch as soon as it enters the pump.
Second option would be to put it in the Temp sensor location and put that in the water pump, it's close enough to reach. But this may always tell the computer it's running colder than it really is cause it's reading incoming coolant temp instead of at the t-stat.
I guess one more option would be to buy a water outlet with a threaded hole in it and put the switch in that.
I may have answered my own question but, discuss....
