Cornfield creations
I put a GMPP 350 HO in my k-5. I used a GM intake manifold that accepts a quadrajet carb. I know the vortecs don't have the coolant bypass built into the heads so you have to run a bypass hose from the intake to the water pump. Well I had a short hose from the front of the intake to the water pump, but I had to put my electric fan temp sensor there. So I moved it to the 5/8 outlet on the driver side of the intake( I believe only GM intakes have this, not the edelbrocks). It cools fine. The problem is I feel it cools too much. I have a 195 thermostat in it and I think that I am bypassing too much coolant throught my 1/2 inch hose going to the water pump.
I am just wondering what other people did to relieve this problem. Could I run my hose from the intake to the heater core and then the other hose from the heater core to the water pump? Right now my hose is going from the radiator to the heater core. I thought maybe If I moved it to the water pump instead it would act as a long bypass from the water pump to the heater core to the intake manifold and would allow it to maintain temp better.
My fans very rarely ever kick on and with summer coming up I am going to have my fans on for the A/C and it will NEVER reach temp.
Just wanting to see what everyone else has done or suggests. THanks in advance guys!
