I agree that it's always good to verify, but I think the real concern is that the temperature swings wildly. Unless the gauge or sender is bad (which is what testing is for) even if the temperature max was 205* (IMO) it shouldn't swing wildly. If the cooling system is adequate, no matter the load/conditions, it should never go above what the thermostat full open temp is.
This is why I advocate using the CTS as the basis of gauge verification. You can watch/record the temperature while driving, which you can't do with any other method short of installing another gauge. It will also tell you if the gauge is fairly close in temp in the first place.
I know you can pull over and stop and check, but I don't think that's always practical.
I know your huge on ALDL cables, and I'm not discounting their value, or that it's info wouldn't verify a gauge reading...but I can easily make the case that an IR gun is a much better overall tool to own for troubleshooting cooling probs for wrench turners..
first an ALDL is exceptionally specialized to our rigs being OBD1, and your only looking at CTS values... plus, even tho the cable is relatively cheap to do, not everyone has a laptop for that.. I don't at the moment....an IR gun is not only useful on a squarebody, but your woman's yota, turbo's, etc, etc..
it can also tell you different temps in a system, lower hose vs upper hose, etc.. it's not just to verify a gauge reading... heck, we take dozens of different readings on boat systems...
like I said, I didn't read about the initial cooling issue and don't know about any wide swings, thus why i asked him in my last post the symptoms, etc...
my original post about an IR gun was, and usually are, to guide the forum to better diagnostics, just like having a mech oil gauge for testing... or a coolant pressure tester... electrical senders should always be the first consideration of failure on any gauge reading, so eliminating that possible fail point is always advisable... isolating the issue...
6 out of 10 times, it's a sender sh*ttin the bed, 1 out of 10 the gauge, if that.. 3 out of 10 are actual cooling probs, therm, pump, etc..
