Not even PVC? He doesn't have a clue, does he?
I'm beginning to think that what I do may be thought of the same way though...
keep in mind... i'm talking off a seacock valve on the bottom of a boat, feeding saltwater to SOME system, wether that's a vibrating engine, ac pump, yada, you will generally have a flexible connection somewhere.. but it's an AC 95% of the time... sometimes a livewell or something...
in other words, giant 12 cylinder twin turbo Detroits (worked on a pair today, cowinkydinckly) will be fed by a 40lb bronze seacock valve that costs about a $G$, with a 5" x3' CG certified hose w/wire to it's raw pump, merrily on it's way, fill a 5 gal bucket in about 5.2 seconds....
most systems that take seawater in thru the bottom of a boat, will be a valve, flexible hose of some sort.. even an IO to some extent..
rigid PVC has it's place, but those are usually fixed, anchored to bulkhead type systems.. water, toilet, central vac, etc... tons of copper for yrs in freshwater systems... 60's, 70's and even some 80's and current trawlers/builders run it for water systems.... tho you better know what your doing winterizing a 55' Grand Banks...
most production boats are into fancier, semi-rigid, PVC, etc, based plastics/hose these days for water systems, AC, etc...
butt the majority of NPT components you'll see are bronze.. pipes on motors, elbows, valves, etc... those Detroit valves would probably scrap for $75 to 100 in bronze.....
