I'm not sure what all the specs are on the motor/induction. If bone stock, low fuel pressure would get you into problems with lean at heavy throttle. If anything other than stock cam/exhaust, etc., there could be some issues with fueling at all times.
But unloaded, with mild mods, I'd not expect the heat from running a bit lean to translate into this big of a problem.
