So, the truck still heats up a bit. And, considering all the work i've done to it (new motor, cooling system, upgraded radiator), plus the amount of towing i'm going to be doing soon, i'd love to get this worked out.
Would some sort of intake leak, or a cracked intake case this issue?
In the last few years, the truck has idled really rough on startup, like it has a vac leak.
Even after doing the intake gaskets a few times, and then one final time on the new Crate motor, it still does this.
Sounds like a poorly tuned carb truck until it warms up.
Intake manifold is original as far as i know. Would some sort of internal or external crack cause my rough startup, and slight overheating issues?
Any other new thoughts on my situation?
Thanks guys!
Its not common,but I have seen a few stock cast iron small block intakes crack under that tin shield that is pinned on the underside (that faces the lifter galley) ,also a few that cracked internally where the heat riser passages channel exhaust gases up under the carb to pre heat the air fuel mixture,and it lets the exhaust gases dilute the fuel/air mixture,makes it run lean,which also makes comburtion temps rise..
However,in all the cases of this I saw,the engines ran better after being started cold,and ran progressively worse as they heated up,probably because the cracks opened up more when hot,and leaned the mixture out..the engines had a stumble on acceleration like a bad accelerator pump,and pinged pretty bad,even with the timing retarded some from stock settings..when another intake was installed (aftermarket ones in most of the time),the engine ran beautifully..and many people threw parts at them and could never get them to run good or figure out why..
I would do what Ryoken said,borrow or rent a pressure tester and put it on the radiator and pump it up,then start it from cold and watch the gauge..if it starts rising suddenly about the same time the thermostat opens it could have a slight head gasket leak thats letting compression sneak into the coolant,but not let coolant get in the cylinder..this makes the coolant foam up and it cant cool the engine good when its foaming..
I recently got 2 Stant radiator tester kits given to me--friend found one complete in a cars trunk he was given to haul away for scrap,and he had another one cluttering up his tool box and has 3 more,so he was going to chuck them!..being a dumpster diver,I didn't let that happen..
I am hesitant to try using them on my old radiators though--might pop them and make a leak with my luck!..
