Interesting. I only went 3 wire cause i couldn't' get the check engine light off with the headers.
Which code was it?
Never had a problem with unheated O2 way back in long tube headers, it just went open loop while idling, but that didn't trigger an O2 code...not sure why yours would unless there is another problem that the O2 is helping to hide, which would manifest itself ONLY under heavy load.
You see this thread? http://coloradok5.com/forums/showthread.php?t=315621
Exact same problem an O2 sensor can't "fix" under heavy load. However an O2 sensor can hide the problem under part throttle/light throttle cruise.
