You've got a champion radiator with plastic tanks? I thought they were all welded aluminum, which was one of their selling points especially for the price. Mine is.
wow I have read this whole thread today.... was the overheating ever fixed?
We had a 89 3/4 ton suburban growing up with a 454. It would overheat every time we pulled the travel trailer. At the time it was only a couple years old. Like you everything was replaced except for the engine. Overheating never stopped.
I think your radiator is too small. even though it is stock size I don't think you are getting enough surface area with airflow. I say get the widest radiator you can even if you have to mod some stuff to make it fit. Surface area is better than thickness imo.
I have a 4 core brass radiator that I used in my 91 c1500. I don't remember the width or the year it was for, but it was for a 1 ton 454 truck. My truck never overheated after installing that. I have pulled a huge travel trailer in 100 degree heat up and down some good "hills" not mountain passes. It never would get past 210. Before the bigger radiator I tried a new stock replacement radiator and it would get almost to the red while pulling.
Rock auto still offers the big all brass radiator but I think it's like almost $400!
Ya know, I'm gonna be that guy I guess.. I've made comments in here before, I'm sure, not gonna go back through this decent sized thread.
I lived in Arizona with those 110° plus summers, the burb when I got it would get a bit warm especially when trying to run the ac, when it worked. This was with a factory style 3 row radiator.
After I replaced the radiator with a "heavy duty cooling" 4 row radiator, not extra wide, and a heavy duty fan clutch, it barely makes it to thermostat temp. Took it back to Indiana with the much colder climate, it never would hit thermostat temp, just kept over cooling.
I'm still going to say that there is something going on with the engine creating an overheating issue. I seriously believe that if a new heavy duty equipped cooling system can't keep it cool, it's not the cooling system, but at least it's seriously trying.
You shouldn't have to be forced to purchase a high performance rated radiator to keep an engine cooled for mild trailer pulling or as you stated previously, pulling it's own weight.
Also to add, the setup I had is still utilizing the factory located engine oil cooler and an aftermarket transmission cooler that is the same size as the engine oil cooler, on the passenger side, both in front of the radiator..
