ah hell i was hoping that front would have been a least a 44 so i could do a little beefing up on it. i will go pick up that 14 bolt this week. Het do you or anyone know how to tell the gear rati on on them
First determine what type of diff you have. Open, locker, limited slip etc. Turn the pinion, if both side rotate in the same direction (forward or reverse) you have some type of locking diff. If one side rotates forward, and the other reverse, you have an open, or a bad limited slip, or locking mechanism. This could be explored more simply by opening the diff cover.
If one sided (open differential), block one axleshaft from turning, then rotate the other side axleshaft until it rotates one revolution, while counting the # of revolutions on the pinion yoke. If its a locker or posi/ limited slip, rotate one side, with the other freely turning (in the same direction) and count the pinion revolutions. This should give a close enough number to match up with 3.42, 3.73, 4.10, or 4.56 gear ratio's.
Good luck.
