Couple new products!!
cybrfire
1 ton status
Iowa
Hydraulic assist ram mount. The one shown is patterned for the Dana 60. 1/2" thick mounting plate. The tab can be configured for any different ram end just let me know what you need. Also comes with the matching tab for the tie rod end of the ram. $49.99.
The last word in heavy duty spring perches. XD spring perches for the mighty 14BFF. 3/8" thick Pieced together, boxed and fully welded. 3 positions for the center pin. Center, +/- 1" or 1.5". Built specifically for the 14 boltFF. Not a grind to match scenario. $61.99 for the pair. These can be custom tailored to add more height if need be.
Radiused shock tab for running your shocks in more of a factory configuration. 1/4" thick steel. 1/2" diameter hole. $4.00 each.
Here's a couple tabs for the guys with some tubing in their ride. Fits 1.75" diam. tube with .5" hole. $2.50 each either design.
Thanks guys. Couple more goodies coming out in the very near future including tube doors which is a high priority as well as another but that one is being kept under wraps until its ready to go.
I would like to order some of your rock rings, but your website is down. Give me a # to call you.
Thanks,
Todd
Yeah the whole domain reg thing is really starting to wear thin on me!:angry1:
You can call me at 712-470-0406.
