Ok so I'm going to be building a suburban. I want it to be as strong as I can make it. I already have a 14bff. I want to do a shave on it and do the high angle driveline 1410 swap on it. What else can I do do make this axle super strong.
Also I will be doing the 203/205 doubler. Can you put 1410 yokes on either side? If not what is the best stronger route for drive shafts.
I will be putting in a dana 60. Still undecided on ford hp or chevy lp. What are the pros and cons of the ford hp. What can be done to either ford or chevy for strength. What is the bigger yoke for the 60s?
