lak2004
Ok first thing, when I get the engine to TDC to set the timing, how do I point the distributor to the #1 cylinder? Is it the little brass looking thing that needs to be pointing to #1? Does anyone have a thread saved on TBI timing as well? Thanks
Also, I just realized that my distributor will need an external coil, is that correct? If so anyone know where I can find the wires that run from the dist to the coil (not just the spark plug wire)? TIA
Ok I know I have asked this before but I cant seem to find the thread where it showed what vacuum lines go where. The only one I remember was the one on the back goes to the MAP sensor. Other?
Can I get a pic of the throttle cable and TV cable bracket and mounting from someone who has a 700r4 and tbi?
Anyone know what this vacuum control piece on the firewall is for? Could it be for my 700r4 lockup? And also what this plug is for?
Will my ESC module be ok if I mount it to the ALT bracket or does it need to be on the firewall?
Thanks in advance guys! I am getting so close to having this thing finally running after 10 months of it sitting. Just need to figure out a few more odds and ends things. Also does anyone have a good write up on flaring fuel lines? I am just going to use the existing ones in my 85 so I have to cut them and flare them to connect to the throttle body. Thanks again!
