Cracked Flex Plate?
Definitely sounds like it's coming from the valve train
if its the flex plate , put tranny in reverse and drive. it will change sounds,, and sometime in reverse it will eliminate the sound
Pulled the flywheel cover off and didn't notice any change in sound, and unless it's cracked between the mounting bolts, it ain't cracked. TC bolts are tight. So now...on to pulling valve covers to check valve train.
Many times this is how they crack. They also crack between each of those large holes.
