Cracked T-case ????
PattBlue
N.W. Pennsylvania
Okay I know it sounds bad BUT...my NP241 has a hairline crack in it at the top of the rear case half, by the rear pump housing. It only leaks when I put it 4-WD. Other than replacing it what do you think to fix it. Everyone around hear says JB Weld it. The crack is about 2 inches long and smooth with no holes.
I'd agree. Just try JB Weld, and if it doesn't work you can go from there.
90K5
Not familiar with a 241, but if the rear case 1/2 supports any bearings and shaft, I would replace it. Then keep the JB welded case as a spare.
<font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
