I have 14b s/f rear and 10-bolt front - 6 lug, 4.10 gears. I just moved to 37" tires and need gears. My plan was to buy a couple sets of 4.88 cogs and set them up myself. I found a complete 10-bolt front axle with 5.13 and a tru-trac that I can probably get in the $300 range. Sounds crazy, but I can't get the front gearset and install kit for less than $220 or so, plus I would get a traction adder. My front is in good shape I could probably get a little $$ in return. I have overdrive and 5.13 is only 5% deeper than 4.88. The rear gearset costs the same in either ratio.
What do you think?
EDIT: no plans for a Dana 60 unless it is almost free.
What do you think?
