crew cab fuel problems?
JUNIOR-K5
SO.CAL
I have a 88 tbi crew cab with dual saddle tanks. I ran one till it ran out of gas and now when I use that tank the truck wont stay on unless I hold the pedal down and it misses and idles up and down like a furd. But the other tank is perfectly fine any suggestions on what to check.:confused:
check the fuel pump pressure from the effected tank.
yes, and I would bet money that it burned out when you ran it out of fuel. Very common problem on fuel injected systems.
