chevyuser74
i know there is a few members on here who have done this id like to talk to em but i dont know who they are anyone help?
i understand this i just want to know what else i will be facing as far as frame issues making wheel wells out of the back doors i can handle
When you build the wheel wells you'll most likely lose a ton of space needed for the rear seat - then what's the point?
wow feel like i posted this over on pirate.
Would he be able to fit a rear Blazer bench seat in that spot? Or something like a Corbeau bench? I can almost visualize it fitting just right.
I was pondering on going this route if my Blazer windshield repair falls through, I probably will use the old rusty CC shell on my current truck after I complete the CC body swap. I'll have to wait and see though.
Just an odd idea. Thats all man. I'm not trying to flame.
A Blazer back seat may work, but a 3rd seat from a Sub might be better, or something like Corbeau's small BAJA back seat would be the easiest.
I still think as mentioned the doors will be the hardest part as essentially the wheel well will be right there.
It would look different thats for sure. Plans for behind the cab if you do this?
Could put the crew cab on the Blazer frame then 4 link the rear with a tube frame/bed to get the rear wheels back some.
You could run 56's flipped around in the rear and move the axle back 4" or 5" with a 0-rate.
I would opt for either of those to preserve the use of the back seat area![]()
Aw hell, it's cheap to have it retubed longer anyway. That's the least of the problems with this project.my only problem with this is that everything back there has been replaced i just had a driveshaft built id be throwing alot of money i just spent 6 months ago away.
Theres someone on here with a crewcab on a shortbed frame.
I like the idea please do it. Link the rear so the tire sits exactly half way through the door. You'll figure the seat out once you tub it. Dont let them talk you out of it. Hell look at Xterra they are practically like that stock.
