Kert, what axle width did you start with? C&C 14ff? How wide is the frame? I assume you widened the wheels as well as moved the center to make them more offset?How wide did you end up with the wheels? Looks like 10"? Looking at doing something similar under the back of my truck but I wanna keep it as narrow as possible.
Thanks.
Width is a standard 14bff. There is a 1.5" spacer on the hub. Wheels were widened 4" each and the centers were left alone. Widening was done all away from the wheel center so backspace essentially stayed the same.
To fit the wheels on the truck, i had to narrow the spring perch spacing to directly under the frame, which I felt could make things less stable. It doesn't feel that way. Tire foot print is very wide and I also added air bags to the suspension.
EDIT: Looking back and toward the future, I think I should have started with a wider wheel and just recentered it to the dually backspace. I have fixturing to do this now which I didn't have at the time. I think I would end up with a more accurate wheel. These aren't bad, and actually roll down the highway pretty smooth once the flat spots are gone. Just the desire to do the best job possible.
EDIT: Was working on it this morning. The 1.5" spacer is on the inboard side of the hub spacing the rotor away from the wheels.
