Crew cab. Use it or lose it.
What are your exhaust plans?
2.5" tube back to a section that will be siamesed together and then split again much like a "H" pipe and then necking up to 3" in to supertrapps exiting in front of the rear tires.
Well sounds awsome reguardless.
Thanks! Looking forward to getting some exhaust on it and fixing a faulty water temp sender. I think at that point I can start driving it regularly while I wait for body shop time.
Looking good Kert! How did you get that fuel pressure problem fixed?
It fixed itself temporarily. When I put the Crew cab inside last night it was back again so I'll have to get a new pump ordered.
It's certainly got some balls. When it started acting up again last night he was clearing it out in neutral and slapped it in gear quick, spun the duals with ease at what sounded like around 2,000 RPM. :eek1:
did you put spacers between the rear tires they look a little close once loaded and sde walls buldge they might rub (could just be the pic)
custom rims.
I can't remember off hand how much space is there but I'm sure it wasn't a problem.
Brett
