I haven't yet. I was thinking I should try to find the problem first.
The cam is spinning 2x faster than crank speed. So if it’s the cam or a cam bearing or a lifter you would have a noise that’s double in frequency than the crank.
Right. I had it backwards in my mind. Thanks for the correction.The camshaft spins at 1/2 crankshaft speed on these engines, not 2X.
I've been hoping it would be something like that, but because it doesn't start until the engine is over 110° I don't think it's something like that.We ran into this on a customer's car a few weeks ago, new engine and trans installation by another shop. I had them trailer it over since they had blamed the trans.
It turned out that they had installed a floor shifter and run the sheet metal screws through the floor to the point the ends were making contact with the transmission case. As the engine and trans rocked around at idle those screws were scratching into the case like nails on a blackboard. It produced quite a chirping noise, especially at idle since it had a little lope to it.
Promising news. Kinda unnerving they are familiar enough with a problem to recognize it from a video, but as long as they stand by the engine it should be ok.Okay, I may have a solution. I filed the warranty claim thru the website and I included a link to the video I posted here. I got a call in less than an hour from a very nice guy in Grand Prairie, TX. He's pretty sure he knows exactly what the issue is and he told me what to check. I'm going to hold you all in suspense until I can see if it is indeed the problem. Hey I'm in suspense too, so you all can share the wait with me.
But I wanted to post up because I am very impressed with the quick, helpful response from ATK High Performance.
Go with the themeDang.... tits on a stick
