crossmember question
sandawgk5
3/4 ton status
Kitsap County PACNORWEST
My crossmember met a rock and it tweaked it to the rear and also jacked the frame flange where it bolts up. My question is will any 208 crossmember work or do I have to get the same type that is in there? The kind I have is the one with the hump on the passenger side only. Also I tried to straighten the frame flange out but was not that succesful can I just use some 1/4 or 3/8 plate on either side of the flange to spread the load out on more of the frame? Any suggestions or opinions are welcome.
Thanks
Ira
Any 1985 on up short adapter x-member should work.
Tom
