Crossmember ?'s
yellowK20
Well Lubricated
Wasilla AK,
I have a 91 R3500 that I'm converting to a "V3500" it has a small block now but future plans call for a Bigblock
since I already have the 2-wheel box installed I'm gooing to be using crossover steering and since I have to remove the 2-wheel suspension and crossmember I want to go with one of ORD's crossmembers
so heres the questions
1 will they work on the 2 wheel drive frame?? ( I assume it will but i wanna ask anyways)
2 if I get the bigblock crossmember will it still work with a small block?
Your 4wd engine mounts will not fit
The 2wd frame is shorter
And the big block crossmember should work
whats different ? I have the complete V truck donor but the frame is bent and broke behind the cab
So what is the difference between a 2WD and a 4WD motor mount?? Is one taller than the other?
