Crossover fun from NWF
jekbrown said:
actually yeah, that does help. If you had to guess, how much taller is the TRE mounting surface compared to a normal straight arm (1" thick). I have WFO arms that rock, but I want some that go up a little bit like the NWF arms do. Just eyeballing it, it looks like it rises maybe 3/4" or so. Every little bit would help...
j
3/4" is what I'd guess, too. I'll try and check better tomorrow, but you'll probably get your answer from the pic 454k30 posted.
I just played around with 454k30's pic in photoshop and it does look like it should be about 3/4" higher than an arm like WFO's.
