Crossover steering for a Dana 60
munepit
3/4 ton status
Bakersfield CA.
Thought I would check here before I buy a kit from ORD. Looking for draglink and steering arm. Let me know if you have anything. Thanks!
Here's a suggestion...
Instead of buying a complete kit from ORD, consider another companies arms and ORD's tie rod and drag links. That's what I did. Went with Ballistic spring-less arms and ORD's tie rod/drag link. I wanted spring-less arms and just standard crossover....Ballistic makes a spring-less cap to go on the driver knuckle, so it worked out pretty good. A little more expensive, but I think the spring-less arms coupled with bronze king pin bushings is worth having a death wobble free truck.
Thanks, I was thinking about that same idea. I can do the tierod, just need the tube and ends. Draglink, I will go with ORD. Thanks for the advice. I'm gonna do that!
