crossover steering
big blaze 18
Registered Member
South Pittsburg TN
ok this is your typical newbie question. is there any way possible to just use my original 4wd steering box for crossover. moneys kinda tight to the point i wont have any to spend on a 2wd box, but im possiably gettin a 60 for the front pretty soon and i was wantin to do crossover when i put the axel under my k5 if i could afford it
You need a new box or swap a 2wd sector shaft into your existing box.
If you are building a 60 surely you know a steering box will be cheap compared to everything else right? :)
yea i know. im gettin a good deal on the 60 or well a set of cucv axles so all my funds will end up goin to them. im probably just gona end up runnin factory set up for a while and see how that does. it mostly gets used for hills and mud anyways so no serious flexin like rocks.
I got 2 for free!! They are out there. At least around here they are. Lots of rusted out older chevys. I have a spare. It's a flare line style, not the o-ring one. You're welcome to it, but shipping would probably be more than finding one in a junk yard locally! Let me know, and I will find out how much from here. I need a zip code though>
Just keep an eye out for a 2wd one. Check junk yards and craigslist.
I got mine for free too.
ill hunt around at sum local yards and see what i can find but thanks if i cant find one ill let ya know.
Yeah, they should be a dime a dozen, mine was free as well.
Martin
